Hey folks. Just got two voice PE’s from ameriDroid. I plugged them in, and immediately had weird behavior from one of the devices.
The first device works as expected. Attached to HA, “Hey Nabu” works, and I can clearly see in HA that it is accepting my voice command, switches to playing, and then responds.
The second device, not so much. It attaches to HA, “Hey Nabu” causes the wake word sound to pop, but then it immediately dies back to “Idle”.
It’s clear something is off, because the light also doesn’t twinkle when it hears the wake word. It cuts off immediately.
I normally do that, but it seems like if I do the device takeover, it breaks the device. It lights up white and stays that way. I’ll avoid adding it to esphome builder, then.
I ONLY take over mine because of the wake word and even then only onthe device I’m experimenting with. Eventually this will be all of mine when I engineer Friday’s final wake word. But… that’s the only reason I’d do it rn personally…
