HA Voice Updates
Each time an update appears for my HA Voice PE device, I attempt to update it wirelessly, expecting it to fail. Every time, I am not disappointed. There are no messages. The update routine simply quits and the update once again appears available. Updating by USB is usually only successful using the HA Voice web updater. Updating locally via USB fails every time as well but with this error:
'Compiling .pioenvs/home-assistant-voice-09996b/src/esphome/components/api/api_connection.cpp.o
xtensa-esp-elf-g++: fatal error: Killed signal terminated program cc1plus
compilation terminated.
*** [.pioenvs/home-assistant-voice-09996b/src/esphome/components/api/api_connection.cpp.o] Error 1
========================= [FAILED] Took 32.65 seconds ========================="
I had a issue with my Rpi locking up and rebooting during ESPHome compiles. I had to compile and update on my desktop instead. (Later upgraded my RPi. Also, i re-installed the Voice PE devices directly in the voice section and didn’t install them in ESPHome at all. This seems to work better for me. Wish i had more, but hope that helps.
