Haaska Configuration
I have went through Haaska setup and I got the test running successfully, the skill enabled and the device found ( a zigbee bulb ) on my alexa app. When I ask Alexa to light it on, it says “OK” but nothing happens. I think I’m missing something obvious :rofl:
I have nothing in my configuration.yaml ( except for the defaults and ssl certificate ) but only
alexa:
  smart_home:
Should I be configuring something here?
Take a look at the following (if you haven’t already).
It looks like the filter is required, so you’ll need to add it using either include, or exclude
Thanks! Been through that already :slight_smile:
Finally I managed to solve it! I had to change the echo device language to match to the Alexa skill language and AWS region.
