I finished Alexa skill, Lambda Function, Register application and added to my Amazon Echo skill. However, it cannot discover the components I have in my home assistant.
I tried to trace back:
- make test in Raspberry Pi = OK
- test in Lambda = issue
Detail below.
What should I do to make it work?
make test in Raspberry Pi result:
pi@raspberrypi:~/haaska $ make test
“header”: {
“payloadVersion”: “2”,
“namespace”: “Alexa.ConnectedHome.System”,
“name”: “HealthCheckResponse”,
“messageId”: “ebd8f280-778e-4bdb-9c8f-18cc863e84d5”
“payload”: {
“isHealthy”: true
true
test in Lambda (Input):
“header”: {
“payloadVersion”: “1”,
“namespace”: “Control”,
“name”: “DiscoverAppliancesRequest”
“payload”: {
“accessToken”: “whatever”
test in Lambda (Error):
“stackTrace”: [
“/var/task/haaska.py”,
660,
“event_handler”,
“ha, payload)”
289,
“invoke”,
“obj = make_class(allowed)(namespace, name, ha, context)”
“errorType”: “AttributeError”,
“errorMessage”: “type object ‘allowed’ has no attribute ‘Control’”
haaska - config.json:
“url”: “https://my_ip:443/api”,
“password”: “my_password”,
“expose_by_default”: false
