Hacking a Blind Motor
I have some MySmartBlinds. They’ve worked brilliantly on their own for the past few years and with their solar panels have been ‘set and forget’.
They’re not without their problems though. Very proprietary, total lack of support with anything, crap if you try to use them with anything other than iOS, no working solution for HA when not running on a Pi and no longer ship to the UK. Lately one of my blinds has lost the plot and seems to do what it wants.
There’s a teardown here.
I’m thinking about robbing the stepper motor from them and DIYing something compatible with HA, preferably RF or Zigbee (I’d use ESPHome but there’s no chance of getting a power supply to where the blinds are).
I’m pretty clueless on RF/Zigbee; does anyone know of a framework like ESPHome with compatible hardware that I can use?
Thanks!
I’m trying to perfect my own ESPHome blinds.
If it’s any help, here’s my code.
esphome:
  platform: ESP8266
  board: d1_mini
  on_boot:
    priority: 800.0
    then:
      - cover.close: cover1
      - delay: 2s
      - servo.detach: my_servo
      - delay: 3s
      - cover.close: cover2
      - delay: 2s
      - servo.detach: my_servo2
wifi:
  ssid: "SSID"
  password: "PASSWORD"
  manual_ip:
    static_ip: IP
    gateway: Gateway
    subnet: SUBNET
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
switch:
  - platform: gpio
    name: "Living Room Front Blinds Status Light"
    pin: 2
    inverted: True
servo:
  - id: my_servo
    output: pwm_output
  - id: my_servo2
    output: pwm_output2
# Example output platform
# On ESP32, use ledc output
output:
  - platform: esp8266_pwm
    pin: D5
    frequency: 50 Hz
    pin: D6
    frequency: 50 Hz
cover:
  - platform: time_based
    name: "Living Room Front Blinds Left"
    open_action:
#      then:
      - servo.write:
          level: -2.0%
    open_duration: 1.2sec
    close_action:
#      then:
      - servo.write:
          level: 20.0%
    close_duration: 2.3sec
    stop_action:
#      then:
      - servo.write:
          level: 0%
    name: "Living Room Front Blinds Right"
    open_action:
#      then:
      - servo.write:
          level: -2.0%
    open_duration: 3.5sec
    close_action:
#      then:
      - servo.write:
          level: 20.0%
    close_duration: 1sec
    stop_action:
#      then:
      - servo.write:
          level: 0%
It uses two servos to tilt two blinds.
They are continuous rotation servos so I just guestimate how long they have to spin in each direction.
Hopefully getting a new, better gearbox graciously printed soon.
