Another thanks to the OP for giving me the courage to hack my Grundfos. TL;DR: I removed the front control board to make it “dumb”, which allowed me to control it with Home Assistant via a relay.
Details: I have a Grundfos ALPHA 15-55 SUC HWR-D Comfort. It is designed for on-demand recirculation which pairs nicely with my tankless heater. It uses remote Bluetooth buttons to initiate cycling the pump on for 5 minutes. Unfortunately, Grundfos did a HORRIBLE job with the Bluetooth implementation. First failure is that the remote devices regularly need to be re-paired (when they actually work). Second failure is that I had to purchase their expensive Bluetooth extender in order to get them to work, even with remotes that were not far away from the pump. Third and fatal failure is the Bluetooth remotes all seem to experience some kind of hardware failure. I have three remotes and they are all dead. There are many reports of others on the web with the same issue. I took one apart and hooked up to power supply set at 3.3V. I can see that the remote powers up and an LED flashes, but one or more components on the PCB are dead. It’s all SMD and I didn’t have the patience to try to trace everything. It appears Grundfos must know about the issue, because from what I can tell they no longer make a similar model and you can no longer purchase the Bluetooth remote as a spare part (one vendor is selling for $500 each!).
Unfortunately, before reading this thread, it seemed it was not possible to put the pump into “always on” mode. If Grundfos is reading, you should put an override switch on all your “intelligent” devices to fallback into always on mode for external control.
Encouraged by this thread, I removed the front panel to expose the top two boards. I removed the topmost control board (which has the LEDs and the button switch), and then powered up the pump. Sure enough, the pump ran non-stop. Success! Thanks to the OP I did not even have to test any of the power connections to determine the logic. I quickly plugged into a power-monitoring relay I was already using to monitor whether the pump was actually on, modified my Home Assistant automation, and now have full control.
I’m actually glad the Bluetooth remotes died. I always desired to control via Home Assistant rather than dedicated remote. Thanks to this thread, it’s now possible.
Front cover of pump installed:
Cover removed with second board exposed:
Top control board that was removed from cover:
Backside of cover after removal, with board removed. You can see there are three tabs in 12, 4, and 8 o’clock positions. Just used a small screwdriver to pry up the cover.
