HACS and TADO couldn't setup?
Hi guys,
I’ve integrated HACS and TADO into my setup but it gives problems alot.
TADO:
Error during setup of component tado
  File "/usr/local/lib/python3.7/urllib/request.py", line 1317, in do_open
    encode_chunked=req.has_header('Transfer-encoding'))
  File "/usr/local/lib/python3.7/http/client.py", line 1244, in request
    self._send_request(method, url, body, headers, encode_chunked)
  File "/usr/local/lib/python3.7/http/client.py", line 1290, in _send_request
    self.endheaders(body, encode_chunked=encode_chunked)
  File "/usr/local/lib/python3.7/http/client.py", line 1239, in endheaders
    self._send_output(message_body, encode_chunked=encode_chunked)
  File "/usr/local/lib/python3.7/http/client.py", line 1026, in _send_output
    self.send(msg)
  File "/usr/local/lib/python3.7/http/client.py", line 966, in send
    self.connect()
  File "/usr/local/lib/python3.7/http/client.py", line 1406, in connect
    super().connect()
  File "/usr/local/lib/python3.7/http/client.py", line 938, in connect
    (self.host,self.port), self.timeout, self.source_address)
  File "/usr/local/lib/python3.7/socket.py", line 707, in create_connection
    for res in getaddrinfo(host, port, 0, SOCK_STREAM):
  File "/usr/local/lib/python3.7/socket.py", line 748, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
  File "/usr/src/homeassistant/homeassistant/setup.py", line 156, in _async_setup_component
    component.setup, hass, processed_config)  # type: ignore
  File "/usr/src/homeassistant/homeassistant/components/tado/__init__.py", line 40, in setup
    tado = Tado(username, password)
  File "/usr/local/lib/python3.7/site-packages/PyTado/interface.py", line 301, in __init__
    self._loginV2(username, password)
  File "/usr/local/lib/python3.7/site-packages/PyTado/interface.py", line 154, in _loginV2
    response = self.opener.open(req)
  File "/usr/local/lib/python3.7/urllib/request.py", line 525, in open
    response = self._open(req, data)
  File "/usr/local/lib/python3.7/urllib/request.py", line 543, in _open
    '_open', req)
  File "/usr/local/lib/python3.7/urllib/request.py", line 503, in _call_chain
    result = func(*args)
  File "/usr/local/lib/python3.7/urllib/request.py", line 1360, in https_open
    context=self._context, check_hostname=self._check_hostname)
  File "/usr/local/lib/python3.7/urllib/request.py", line 1319, in do_open
    raise URLError(err)
urllib.error.URLError: <urlopen error [Errno -3] Try again>
For HACS:
Unable to install package aiofiles==0.4.0: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f6111b15a90>: Failed to establish a new connection: [Errno -3] Try again')': /simple/aiofiles/
  WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f6111b038d0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/aiofiles/
  WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f6111b03b50>: Failed to establish a new connection: [Errno -3] Try again')': /simple/aiofiles/
  WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f6111b032d0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/aiofiles/
  WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f6111b03fd0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/aiofiles/
  WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f6111b036d0>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.10/amd64/
  WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f6111b03090>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.10/amd64/
  WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f6111c83f10>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.10/amd64/
  WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f6111c83d50>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.10/amd64/
  WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f6111c83c10>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.10/amd64/
  ERROR: Could not find a version that satisfies the requirement aiofiles==0.4.0 (from versions: none)
ERROR: No matching distribution found for aiofiles==0.4.0
Why is this and how to fix it?
It’s limiting me to restart homeassistant from the UI after changes until I exclude these.
I have adguard home running btw.
Thanks,
Dennis
bump bump anyone?
