I am trying to Install HACS. I get to the step where GitHub says the authentication goes through, but when I go back to Home Assistant it acts as if the authentication hasn’t occurred and stays on that screen. Please help
HACS Discord is another source for HACS setup help
Thank you for the advice. I have posted there as well. No response yet, still looking for a solution.
I have this error in the logs, does it give any clue?
Uncaught error from WebKit 605.1.15 on iOS 18.7 ReferenceError: Can’t find variable: elementId /config/integrations/dashboard:24:57 global code (/config/integration
This is full message
Logger: frontend.js.modern.202603040
Source: components/system_log/init.py:331
First occurred: 1:05:45 PM (8 occurrences)
Last logged: 1:33:41 PM
- Uncaught error from WebKit 605.1.15 on iOS 18.7 ReferenceError: Can’t find variable: elementId /config/integrations/dashboard:24:57 global code (/config/integrations/dashboard:28:3)
- Uncaught error from WebKit 605.1.15 on iOS 18.7 ReferenceError: Can’t find variable: elementId /config/logs:24:57 global code (/config/logs:28:3)
