HACS disappeared completely
I am using a virtual machine version of home assistant on my linux based OS with 33G of memoory and an AMD Ryzen 5 processor.
I have been using the latest release of home assistant without issue for the last week, but suddenly when I use the app or local link, the HACS integration is no longer on the menu, and all my custom inregrations, cards like mushroom and the firemote card I use to conrol my devices have stopped working completely. I have tried refreshing, I have tried re-installing, nothing is working. Anyone have any ideas what I’m doing wrong?
Sometimes my icon disappears in the side bar. What happens if you go to >Settings >Devices & Services ? Can you see it in the integrations menu?
No, all my installed apps are non functional, and the integration has congiguation error… I tried to delete it and re-install, but it won’t let me.
Can you re-configure it?
HACS is simply a custom Integration that helps you install other Custom things from GitHub and keeps track of if they have been updated. It controls nothing
HACS is missing for the same reason all the other Custom Integrations are missing. No, I don’t know why that is, but HACS is not some software that controls other things. It’s a loader program.
At first it wouldn’t reconfigure, but then it did. I think it was some weird random glistch that started when my router re-assigned a bunch of ip addresses.,
