I just upgraded my HA docker system (with docker-compose pull
and docker-compose up -d
), and now HACS won’t load.
2025-07-02 13:04:41.894 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry for hacs
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 749, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File "/config/custom_components/hacs/__init__.py", line 246, in async_setup_entry
setup_result = await async_initialize_integration(hass=hass, config_entry=config_entry)
File "/config/custom_components/hacs/__init__.py", line 214, in async_initialize_integration
await async_try_startup()
File "/config/custom_components/hacs/__init__.py", line 201, in async_try_startup
startup_result = await async_startup()
File "/config/custom_components/hacs/__init__.py", line 170, in async_startup
async_register_frontend(hass, hacs)
File "/config/custom_components/hacs/frontend.py", line 68, in async_register_frontend
hass.components.frontend.async_register_built_in_panel(
Also, some of my other integrations won’t load either (e.g. MyEnergi - but I imnagine it needs updating via HACS).
HA version is 2025.6.3
