Hello everyone,
I installed the Fordpass integration on the HACS:
Since yesterday, I’ve only been getting connection errors.
I read in the integration that these problems were caused by changes from Ford.
There was information there to install version 1.70 manually.
I did that.
There was also information on how to get the token:
I used this to find the token and enter it into Home Assistant.
Unfortunately, I get this error message:
Token is invalid, please check you copied the correct token from the Header Location, it should start with fordapp://
But I definitely copied the token correctly.
Is anyone else having this problem and have any ideas what else I can do?
