twingo999
(Twingo999)
1
Hi @all, copied HACS using a Terminal with wget -O - https://get.hacs.xyz | bash -” . I get this error: ERROR: ‘unzip’ is not installed
After starting it in HA i get : could_not_register
Do i have to umzip HACS first? Hw is the command. (not very familiar with unix)
Thank you
Nick4
(Nick)
2
Hi, welcome to the forum!
You can install the zip tool with sudo apt install zip
If you have a problem with this, are you sure that HA Core is the right way for running HA for you?
THB: I’m not…
