I use Ingress to rename multiple Zigbee2MQTT installations on the sidebar. Following the 2026.8 update the MQTT screen has now been reduced to 1 inch. Has anyone else had this isuue and found a resolution.
Have you cleared the front-end cache?
in ingress or MQTT. I cant get to any MQTT functionality as the screen will not scroll.
Front end cache in HA.
Sorry yes done a frint end cache reset
Its an HACS Ingress issue as If I i go into the 2 MQTT configs and set the config to “show in sidebar” then I can run MQTT in full page on both installations. If I go to MQTT through apps I can also run both installations by running the web UI. Its only the HACS Ingress integrations that MQTT will not run in properly.
Time to raise an issue on the Hacs ingress custom component, then
Have managed to resolve the issue with this HA 2026.8 breaks view · Issue #103 · lovelylain/hass_ingress · GitHub a temporary update to Ingress
