I have new HA install (OS) and I am not able to install HACS. Based on HACS installation guide I have tried both commands in Terminal & SSH UI:
wget -O - https://get.hacs.xyz | bash -
Error I am getting in Terminal is as follows:
‘Connecting to get.hacs.xyz (172.67.143.44:443)
wget: error getting response: Connection reset by peer’
Terminal log says:
‘[2023/06/06 09:48:46:7141] N: WS closed from 172.30.32.2, clients: 0
[2023/06/06 09:48:46:7142] N: killing process, pid: 402
[2023/06/06 09:48:46:7143] N: __lws_lc_untag: – [wsisrv|12|adopted] (0) 29.833min
[2023/06/06 09:48:46:7175] N: process killed with signal 0, pid: 402
[2023/06/06 09:48:46:8118] N: __lws_lc_tag: ++ [wsisrv|13|adopted] (1)
[2023/06/06 09:48:46:8142] N: HTTP / - 172.30.32.2
[2023/06/06 09:48:47:0154] N: HTTP /token - 172.30.32.2
[2023/06/06 09:48:47:0802] N: WS /ws - 172.30.32.2, clients: 1
[2023/06/06 09:48:47:0840] N: started process, pid: 407’
I have tried also via https://raw.githubusercontent.com/hacs/get/main/get but issue is the same.
Any guidance and help is appreciated.
Thank you,
//T
