HACS install: No instructions in log
In the docs for installing HACS, step 4 says
Navigate to the add-on logs and follow the instructions given there.
But when I go to the log, there are no instructions, just the normal log content. What am I supposed to do for step 4?
Are you going to the HA logs, or the logs of the Addon?
I went to settings > system > logs > then drop down to GetHACS. If those are the wrong ones, where do I find the right ones?
Where in the documentation does it say you have to read the logs?
HACS is an integration and not an addon!
EDIT: I see the line. Guess the install method have change a bit, since I installed it.
Well, if it is an addon, then look for it under the addon section in the settings instead.
There is an install Add-on that makes it easier for install with HAOS.
Thanks for the come-backs all. I just proceeded to install it and it worked. Now I have another problem but I will start a different thread for that.
