I’m using this custom integration to monitor from Home Assistant 2 mowers. Only problem, this integration keeps disconnecting. But when I restart it works fine for 20 minutes and then disconnects. I was wondering if someone had a fix for this issue.
Note the mowers used are model number 310 and the automower connect module installed afterwards
And this Ha Automower integration works fine evean when the prior fails. I steel want to use the first one because it uses the official API ad seems more frequently updated
After enabling the debug I get this error message in the ha logs
Logger: custom_components.husqvarna_automower.entity
Source: custom_components/husqvarna_automower/entity.py:74
Integration: Husqvarna Automower ([documentation](https://github.com/Thomas55555/husqvarna_automower), [issues](https://github.com/Thomas55555/husqvarna_automower/issues))
First occurred: 22:38:38 (3 occurrences)
Last logged: 22:39:18
Connection to Maison lost
