Hello all, I’m hoping for some guidance. I successfully installed HACS integration on my HA instance that is running as a docker container. After installation HACS ran fine for a few days. Today I get this notification and my HACS isn’t loading….not sure how to fix it. Any help is appreciated. Below is the error noted in the logs….
Logger: homeassistant.setup
Source: setup.py:210
First occurred: 4:27:42 PM (1 occurrences)
Last logged: 4:27:42 PM
Setup failed for custom integration hacs: Unable to import component: cannot import name ‘locate_dir’ from ‘custom_components.hacs.hacs_frontend_experimental’ (unknown location)
