HACS issues (I think)
I’ve been trying to update Bubble card to V3.0.0# via HACS, but after several attempts, reboots, remove and re-install files manually AND via HACS, V2.4 is still the one that’s sticking…
I even tried removing it, restarting, then as a sanity check I went into a dashboard that uses a lot of bubble cards and it was in fact giving errors, I tried adding a bubble card but it wasn’t an option in the “add card”… THEN i re-installed it via HACS, selecting V3.0.0-rc.3… and when I add a bubble card and scroll to the bottom of the config window it still says V2.4… I also get this in HACS:
Did you clear your browser cache ?
yup, and tried on several devices…
