HACS no longer availabale
Not sure when it happened but I have been using HACS for years and with all the changes in supported platforms I am on HAOS now. Not sure if that’s when it happened but I show HACS in the integrations but not on the left side. Can’t really find a way to add new integrations thru HACS anywhere. Looking at some videos seems there is a whole convoluted way of activating an install but I already have it installed and can’t install it again. Thoughts?
Have you tried the good 'ole browser cache flush?
Sometimes the icon just disappear too, but the button is still there to click.
It can also be that changes in the way the user GUI configuration works have deseocted or hidden it, so you need to reenable it in your user setting by editing the sidebar.
Thanks for the replies, tried those nothing worked. I ended up removing the HACS integration and then going thru the process of registering it again and all and it came back then. Note everything I installed as part of it still SEEMS to be there.
