HACS not loading. Popup error Unable to load the panel source: /hacsfiles/frontend/entrypoint.js
Hi, I recieve the above error, tried to reboot the host, but still same issue.
Any hint?
Same problem here. In my log i see “Removing unknown panel hacs”?
Problem solved! After delete HACS and install again with a new “keycode” its working again.
How do you deete it?
I did remove the integration, restarted HASS, then readded HACS integration, but it shows this, and its not working
immagine_2021-02-07_092224
Yes, did the same. Remove, restart HA and then install again. Did you have to connect (using a code) to connect to GitHub? I cant remember using this the first time.
Trying to remove it all. But do not understand where this directory is (.storage)
  1. Delete all files and directories containing hacs under the .storage directory.
Under the tab Configuration and then Integrations klik on HACS then Delete.
yes that I did already
When I updated to 2021.2.1 it broke my HACS. It failed to load.
Restored my system back to 2021.1.5 and it works fine again.
Mind you 2021.2.1 also flagged up issues with Recorder that I did not understand.
Ahhh yes I have now 2021.2.1
I have the same issue with the 2023.12.4 core version. But there is a workaround. HACS is still accessible via the phone app. Once you accessed it there, you can access HACS in the browser again. Not very convenient, but it might help…
same issue with 2025.1.1
