PetTracer Integration for Home Assistant
A Home Assistant custom integration for PetTracer GPS pet trackers.
How to install, follow the Github link
Features
GPS Location Tracking - See your pet’s location on the Home Assistant map
Signal Strength Monitoring - Track GPS signal strength in real-time
Battery Level - Monitor tracker battery status
Battery voltage - Monitor tracker battery voltage
Battery status - Monitor tracker battery status (charging,discharging, full, off)
Multiple Sensors - Signal percentage, dBm, battery, and signal level
Auto-refresh - Via Websocket based on your mode
Multi-device Support - Works with multiple trackers on one account
Hardware information - From software version to hardware version
All the modes - Showing all the modes of the collar, even the hidden ones!
Buzzer and Led status - Showing the current status of them
Search mode information - When search mode is enabled you get all the insight info
Collar colour - Expose your picked colour and can be used as SVG
Home stations - Show all your home stations and which wifi is connected- ⏻ Turn off - Be able to turn off the collar
