HACS Repository downloaded....now what?
I got HACS installed and now I want to install the ChargePoint integration. I found and downloaded the repo, but am not sure what to do now. Per instructions I restarted HA. When I go to HACS > ChargePoint for Home Assistant there is the readme from the Git repo with a link that says
Install the integration like you would any other HACS addon.
But that link is broken. I’ve look through the docs and don’t find anything that explains what to do next. What do I need to do to get this running?
The steps you did is how to install from hacs, now continue to the next paragraph in the readme:
Once you have installed the component, you’ll need to add and configure it. From theConfiguration > Devices & Services page, click + Add Integration in the bottom right.
OK thanks. Not sure how I missed that…
No worries, that’s what the forum is for :slight_smile:
