Hello together,
I have the following issue. HACS is only showing updates after a system restart. Does some has a solution for that?
Best regards
Hello together,
Best regards
HACS will only show updates after it polls for updates on github which is rate limited. So your options are: Restart, or be patient.
Ok. I only had in my mind that it polled much more in the past - but maybe I was wrong.
ty
It did poll more in the past, then github contacted the HACS owner and told him too many people were polling too often.
If you enable experimental features on HACS config it’s faster because of this: https://experimental.hacs.xyz/faq/data_sources/
