Hadashboard Darksky Units Incorrect
Have setup darksky in HASS configuration.yaml with ‘ca’ units
- platform: darksky
  api_key: xxx
  monitored_conditions:
    - summary
    - apparent_temperature
    - pressure
    - precip_type
    - precip_probability
    - temperature
    - humidity
    - precip_intensity
    - wind_speed
    - wind_bearing
    - icon
  units: 'ca'
  update interval:
    minutes: 10
and Haweather in Hadashboard main.erb as follows
<li data-row="1" data-col="3" data-sizex="2" data-sizey="2">
  <div data-id="weather" data-view="Haweather" data-unit="&deg;C" data-color="#FF0000"></div>
</li>
but it’s still showing rain in inches and wind speed in Mph
On the HASS developer screen these show up ok.
What am I doing wrong?
Cheers, Ron
I would like to know too, the widget seems to accept an (undocumented) units: “° C” parameter, to change temp to C, but I still get rainfall in inches and wind speed in Mph.
Documentation is here, for those looking for it, currently no indication of how to specify units.
http://appdaemon.readthedocs.io/en/latest/DASHBOARD_CREATION.html#weather
For completeness, I have the following in my dashboard:
weather:
widget_type: weather
units: "°C
I couldn’t find any follow up posts. I found that the units (other than temperature) are hard-coded into the widget’s html. I edited basegroup.html to show mm, hPa and m/s. The values from Home Assistant are in the correct units.
I also edited the css & weather.yaml to support a title & title2 with styles
I modified
/usr/local/lib/python3.5/dist-packages/appdaemon/widgets/weather.yaml
/usr/local/lib/python3.5/dist-packages/appdaemon/widgets/baseweather/baseweather.html
/usr/local/lib/python3.5/dist-packages/appdaemon/widgets/baseweather/baseweather.css
I suppose I should have created a custom widget rather than editing directly?
