I’ve been using a Hampton Bay fan w/built in Zigbee since before the pandemic. I am using the built in ZHA integration. I wanted to mess around with zigbee2mqtt, so using a separate Zigbee USB stick I spun it up, removed the fan from the ZHA integration and tried letting zigbee2mqtt discover it. It wouldn’t pair with zigbee2mqtt and the new adapter, so I bailed back to ZHA for the time being.
The issue is that the fan always gave 6 speed options in HA, on|auto|smart|low|med|high. Now when paired with ZHA it only shows on|auto|smart. This isn’t ideal since we generally set the speed to our liking using low|med|high. Even weirder, the slider for the fan in HA will let me set the speed to low|med|high, which works fine via the HA app/web page.
I also use Nabu Casa to control the fan through the Google Assistant. Asking Google to change the speed to low|med|high just results in Google responding “Sorry, I don’t understand”.
I reverted HA to 2021.6.6 and setting the speed via Google Assistant works fine. Upgrading back to 2021.7.1 breaks it.
Has anyone else noticed this? I want to make sure I’m not crazy before I raise an issue on github.
Yeah that must be it. using those specific % values works.
hopefully that change can be reverted to some extent to allow using both high|med|low and %, though I can imagine some challenges. maybe allow us to define the % for high|med|low so the user can map them to % that will work for their specific fan.
I’ve tried to get it reverted and tried to get them to support both but I’ve been shot down.
I think it’s asinine to require people to change to saying percentages when 1 - people have been using speeds forever even before home automation was thought of and 2 - it’s not natural language to use percentages when thinking of speeds. Hence, why pretty much every multi-speed fan with distinct speed settings uses words to describe speeds and not percentages.
I agree with you. Something this counter-intuitive seems like it would hinder adoption in some homes. I don’t feel like digging into it at the moment, but maybe there is a workaround to be had through automations or a routine in Google Assistant.
The change was probably so that they could support more that 3 speeds. A lot of new fans (especially DC ones) have more than 3 speeds, i have seen some with 6 or more, not sure how they could ad names to each speed for them
I get why they added the ability to use percents to accommodate fans with more speeds.
I don’t get why they decided to break others fans just to accommodate those others.
the original change to percents/modes was made a couple releases ago but the ability to use the named speeds and percent speeds/modes peacefully coexisted during that transition.
So I don’t get why they couldn’t continue to coexist and support both fan models at the same time?
