Haos 15.0 -> 15.1
Another update and another problem.
I’ve lost communications with one ZigBee hygrometer device, it won’t come back.
Plus the ping to the mobile is failing after months if reliable implementation.
It’s slowed to the point of timing out on initial connection and peaked from 0.6% processor to over 25%…
I’ve restarted, rebooted and just left it, it’s not very stable.
You haven’t given us much to work with.
Z2M or ZHA?
Logs?
Your implication is it’s limited to an interface, it isn’t. I’ve got significant delay in the interface, button reactions etc. I do have interface speed issues but not in isolation.
I’ve had several timeouts simply trying to connect to the front end.
The latest Core update has mediated some of them, but I’m still getting connection timeout.
Plus the <1% CPU is often > 1.5% and sometimes running at 25% which must mean systemically there’s more going on requiring additional processor usage.
Because you specifically asked I have 33 ZigBee devices on a SONOFF 3.0 USB running on a Pi4 4GB
That is not what I asked.
so what are you asking for?
I’ve just suffered a complete system failure and had to power off.
My entire system is defined in this thread what don’t you know that you need?
