I am running HAOS 14.2 on a RPi5 and trying to update to the latest 15.0.
The update fails with the error message:
Failed to perform the action update/install. Error updating Home Assistant Operating System: Unknown error, see supervisor
I tried restarting HA core as well as rebooting the RPi - but continues to fail.
Supervisor log shows the following error:
2025-03-23 22:29:51.280 INFO (MainThread) [supervisor.os.manager] Fetch OTA update from https://os-artifacts.home-assistant.io/15.0/haos_rpi5-64-15.0.raucb
2025-03-23 22:29:55.017 INFO (MainThread) [supervisor.os.manager] Completed download of OTA update file /data/tmp/hassos-15.0.raucb
2025-03-23 22:29:55.078 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-193081' coro=<UDisks2Manager._interfaces_added() done, defined at /usr/src/supervisor/supervisor/dbus/udisks2/__init__.py:190> exception=DBusInterfaceError('D-Bus object /org/freedesktop/UDisks2/block_devices/dm_2d0 is not usable, introspection is missing required properties interface')>
File "/usr/src/supervisor/supervisor/dbus/udisks2/__init__.py", line 202, in _interfaces_added
self._block_devices[object_path] = await UDisks2Block.new(
object_path, self.dbus.bus
File "/usr/src/supervisor/supervisor/dbus/udisks2/block.py", line 78, in new
await obj.connect(bus)
File "/usr/src/supervisor/supervisor/dbus/udisks2/block.py", line 69, in connect
await super().connect(bus)
File "/usr/src/supervisor/supervisor/dbus/interface.py", line 96, in connect
File "/usr/src/supervisor/supervisor/dbus/interface.py", line 50, in connect
await self.initialize(await DBus.connect(bus, self.bus_name, self.object_path))
File "/usr/src/supervisor/supervisor/dbus/interface.py", line 104, in initialize
raise DBusInterfaceError(
f"D-Bus object {self.object_path} is not usable, introspection is missing required properties interface"
supervisor.exceptions.DBusInterfaceError: D-Bus object /org/freedesktop/UDisks2/block_devices/dm_2d0 is not usable, introspection is missing required properties interface
2025-03-23 22:29:55.118 ERROR (MainThread) [supervisor.os.manager] Home Assistant Operating System update failed with: Failed mounting bundle: Failed to open /dev/dm-0: No such file or directory
