Hello to everyone.
I have BT Speaker connected to HAOS. I also have shell script that I execute if speaker is disconnected ( ./bt_music_connect.sh)
#!/bin/bash
MAC="54:D9:32:02:50:65"
powered() {
echo "show" | bluetoothctl | grep "Powered" | cut -d " " -f 2
connected() {
echo "info ${MAC}" | bluetoothctl | grep "Connected" | cut -d " " -f 2
while true
do
sleep 1
if [ $(powered) = yes ] && [ $(connected) = no ]; then
echo "connect ${MAC}" | bluetoothctl
sleep 5
fi
if [ $(powered) = yes ] && [ $(connected) = yes ]; then
echo "Succesfull connection to ${MAC}"
exit
fi
done
I would like to have entities or device with entities that will have values that i get from shell script (connected or not)
Further searching I found that with curl command I can send sensor values and that is clear. I am not clear with authentication even reading documentation.
Thank you.
