HAOS freezes up every other day
My HAOS keeps freezing up. The Host log doesn't seem to indicate much. I run Frigate Full Access on an HP Z2G5 Mini Workstation
2026-06-25 21:11:41.617 HAOS-Z2G5 systemd[1]: Started Hostname Service.
2026-06-25 21:11:41.621 HAOS-Z2G5 systemd[1]: Starting Time & Date Service...
2026-06-25 21:11:41.636 HAOS-Z2G5 systemd-timesyncd[732]: Network configuration changed, trying to establish connection.
2026-06-25 21:11:41.700 HAOS-Z2G5 systemd[1]: Started Time & Date Service.
2026-06-25 21:11:41.775 HAOS-Z2G5 systemd-timesyncd[732]: Contacted time server 162.159.200.123:123 (time.cloudflare.com).
2026-06-25 21:12:11.629 HAOS-Z2G5 systemd[1]: systemd-hostnamed.service: Deactivated successfully.
2026-06-25 21:12:11.733 HAOS-Z2G5 systemd[1]: systemd-timedated.service: Deactivated successfully.
2026-06-25 22:01:06.304 HAOS-Z2G5 dockerd[743]: time="2026-06-25T17:01:06.304091483-05:00" level=error msg="failed to validate image signature" error="resolving signature chain for image sha256:5a1c66f9a57fbca4cbc303973dee48aa3e0f0240632e9012f714e7aa1bce1f2c: expected image index descriptor, got application/vnd.oci.image.manifest.v1+json"
2026-06-25 22:01:06.306 HAOS-Z2G5 dockerd[743]: time="2026-06-25T17:01:06.306180860-05:00" level=error msg="failed to validate image signature" error="resolving signature chain for image sha256:607ef64028402c0ac6127a61fd820d14937d5b5bece696a033dd0c3ca78eaeb8: expected image index descriptor, got application/vnd.docker.distribution.manifest.v2+json"
2026-06-25 22:01:06.306 HAOS-Z2G5 dockerd[743]: time="2026-06-25T17:01:06.306609655-05:00" level=error msg="failed to validate image signature" error="resolving signature chain for image sha256:24b9f8bfd7e43df0b38bb5871ca66847a633ffe4b8d7c70ba1684ff38a1ec977: expected image index descriptor, got application/vnd.oci.image.manifest.v1+json"
2026-06-25 22:01:06.307 HAOS-Z2G5 dockerd[743]: time="2026-06-25T17:01:06.307242455-05:00" level=error msg="failed to validate image signature" error="resolving signature chain for image sha256:97a0abe0595aff9850373cf426609a9558c322ab66f3d58a22191a45602980e5: expected image index descriptor, got application/vnd.oci.image.manifest.v1+json"
2026-06-25 22:01:06.319 HAOS-Z2G5 dockerd[743]: time="2026-06-25T17:01:06.319435639-05:00" level=error msg="failed to validate image signature" error="resolving signature chain for image sha256:c4015f4d01991a049d95ee93d8da4638cb311293a1223b2cb23de9846d37bdaa: expected image index descriptor, got application/vnd.docker.distribution.manifest.v2+json"
2026-06-25 22:01:06.320 HAOS-Z2G5 dockerd[743]: time="2026-06-25T17:01:06.320169435-05:00" level=error msg="failed to validate image signature" error="resolving signature chain for image sha256:d971187a9fdc8957f40475208685042380cf0c7534fd2009d5ecc949712fd91e: expected image index descriptor, got application/vnd.oci.image.manifest.v1+json"
2026-06-26 00:36:25.943 homeassistant kernel: Linux version 6.18.35-haos (builder@3194645ed327) (x86_64-buildroot-linux-gnu-gcc.br_real (Buildroot -g89ddb158) 13.4.0, GNU ld (GNU Binutils) 2.43.1) #1 SMP PREEMPT_DYNAMIC Thu Jun 18 17:07:54 UTC 2026
2026-06-26 00:36:25.943 homeassistant kernel: Command line: BOOT_IMAGE=(hd0,gpt4)/bzImage root=PARTUUID=a3ec664e-32ce-4665-95ea-7ae90ce9aa20 rootwait zram.enabled=1 zram.num_devices=3 systemd.machine_id=91b9647a639348efa18a5c39b7cc8555 fsck.repair=yes console=tty0 rauc.slot=B
2026-06-26 00:36:25.943 homeassistant kernel: x86/CPU: Running old microcode
2026-06-26 00:36:25.943 homeassistant kernel: BIOS-provided physical RAM map:
I pulled the power cable and booted it back up at 2026-06-26 00:36:25.943.
Is there a way to have it be more detailed in the logs?
I have a daily reboot automation but it still sometime freezes up randomly.
Check the core log.
Also check your resource use (RAM, CPU, etc...).
The error indicated shows it is complaining something about time as well, so make sure you clocks are all set correctly or synced properly.
