HAOS missing generated av Python package
Hi there,
I upgraded to HAOS 15.2 and encountering this issue:
Error during setup of component stream: Error relocating /usr/local/lib/python3.13/site-packages/av/../av.libs/libopenmpt-108161a8.so.0.4.4: _ITM_deregisterTMCloneTable: symbol not found
Because of it, I can’t use the TP Link integration anymore:
Unable to set up dependencies of 'tplink'. Setup failed for dependencies: ['stream']
Unable to set up dependencies of 'default_config'. Setup failed for dependencies: ['stream']
I tried to restart the system, but it didn’t work. How can I fix it?
Thanks for your help.
