HAOS on APU2, cashes(?), restarts
Hi
in the past I used to run a very stable HA/HAOS in a VM on my big Unraid Rig. Since I had a spare APU2 sitting unused and wanted to safe a couple of bucks on the energy bill I thought it would be a good idea to utilize the spare APU2.
Installation and backup recovery was largely uneventful, but HA keeps restarting every day or so.
Where should I start to debug? Which logs should I look at?
Thank you and kind regards,
Pete
Which model APU2?
How much RAM?
How much disk space? Total/used/free?
Any entries in the system log? (Settings/System/Logs)
Hi
APU.2C4 with 4GB RAM
I started out on 16GB msata and then used „move data disk“ to move it to an SSD…
30.2 GB of 234.7 GB used
  • System 25.8 GB
  • App data 0.6 GB
  • App configuration 0 GB
  • Media 0 GB
  • Backups 2.5 GB
Last restart completed April 4, 22:26, this is what is in the log:
April 4, 2026 at 22:27:23 – (WARNING) go2rtc - message first occurred at April 4, 2026 at 22:27:23 and shows up 6 times
Go2rtc unexpectedly stopped, server log:
exit with signal: terminated
April 4, 2026 at 22:27:22 – (WARNING) go2rtc
Updating denonavr media_player took longer than the scheduled update interval 0:00:10
April 4, 2026 at 22:27:19 – (WARNING) Media player - message first occurred at April 4, 2026 at 22:27:09 and shows up 5 times
Error fetching NUT resource status data: Error fetching UPS state:
April 4, 2026 at 22:27:15 – (ERROR) Network UPS Tools (NUT)
Update of media_player.denon_avr_1912 is taking over 10 seconds
April 4, 2026 at 22:27:09 – (WARNING) helpers/entity.py - message first occurred at April 4, 2026 at 22:27:09 and shows up 3 times
Waiting for integrations to complete setup: {(‘zha’, ‘01KM0YGNKNQR35QGZDG86CZJV6’): 142.766276403, (‘frigate’, ‘011276c0a808220fbae5cedf209586d9’): 155.294521059, (‘dingz’, ‘dda2cf585aabaa7b2b24167896ea37c3’): 155.601839798, (‘dingz’, ‘7670ed7d82083270290a84a9a099f72e’): 155.755439914, (‘dingz’, ‘a2ea610788f938ace7bba79f00105018’): 155.880357203, (‘dingz’, ‘67c287270902f13e5c5128abf0a78e4e’): 156.027647416, (‘nodered’, ‘01JEV48C5DBJDB1C1R8E3DF3RA’): 156.242762088, (‘tasmota’, ‘0bbcce06b518f9abd8fcb3d145372fd6’): 157.747934284}
April 4, 2026 at 22:26:13 – (WARNING) bootstrap.py
The configuration for entity sensor.laptopr_webcamprocess uses the deprecated option object_id to set the default entity id. Replace the "object_id": "Laptop_webcamprocess" option with "default_entity_id": "sensor.Laptop_webcamprocess" in your published discovery configuration to fix this issue, or contact the maintainer of the integration that published this config to fix this. This will stop working in Home Assistant Core 2026.4
April 4, 2026 at 22:26:09 – (WARNING) MQTT - message first occurred at April 4, 2026 at 22:26:07 and shows up 10 times
Config entry ‘Volvo’ for volvo integration could not authenticate: (‘Unauthorized’, ‘token refresh’)
April 4, 2026 at 22:26:04 – (WARNING) config_entries.py
The deprecated argument hass was passed to verify_domain_control from argoclima. It will be removed in HA Core 2026.10. Use verify_domain_control without hass argument instead, please create a bug report at Issues · nyffchanium/argoclima-integration · GitHub
April 4, 2026 at 22:25:33 – (WARNING) helpers/deprecation.py
Value {‘points’: , ‘mode’: ‘random_pixelated’, ‘points_capable’: 5, ‘mode_values’: [‘interpolated_palette’, ‘interpolated_palette_mirrored’, ‘random_pixelated’, ‘segmented_palette’], ‘pixel_count’: 20} of type <class ‘dict’> is invalid for Light.gradient, expected value of type aiohue.v2.models.feature.GradientFeature | None
April 4, 2026 at 22:25:30 – (WARNING) runner.py
Ended unfinished session (id=264 from 2026-04-04 02:12:57.816988)
April 4, 2026 at 22:25:11 – (WARNING) Recorder
The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
Thank you
Do you see anything that might cause the restart?
Thank you and kind regards, Pete
