Followed the unsapported the installation path. Everything is fine and working. Until i decided to remove apparmor. Upon doing that container ls showed nothing. Wen through the internet. Found out that the cause might be because of snapd. Installed apparmor and snapd back. Now the containers show up (xx in id brought intentionally)
sudo docker container ls -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
9ff5dc9xx435 homeassistant/amd64-addon-mosquitto:6.0.1 "/init" 39 hours ago Exited (129) 36 hours ago addon_core_mosquitto
8772568xx4c0 ghcr.io/home-assistant/amd64-hassio-multicast:2022.02.0 "/init" 39 hours ago Exited (0) 36 hours ago hassio_multicast
745a95xx620c ghcr.io/home-assistant/amd64-hassio-audio:2021.07.0 "/init" 39 hours ago Exited (0) 36 hours ago hassio_audio
2d1abxx74a8a ghcr.io/home-assistant/amd64-hassio-dns:2021.06.0 "/init" 39 hours ago Exited (0) 36 hours ago hassio_dns
00910xx37bc1 ghcr.io/home-assistant/amd64-hassio-cli:2021.12.0 "/init /bin/bash -c …" 39 hours ago Exited (0) 36 hours ago hassio_cli
f44c1xx58834 ghcr.io/home-assistant/qemux86-64-homeassistant:2022.3.4 "/init" 42 hours ago Exited (0) 36 hours ago homeassistant
d5594xxf354d homeassistant/amd64-addon-zwave_js:0.1.54 "/init" 42 hours ago Exited (0) 36 hours ago addon_core_zwave_js
812f6xxd4a85 esphome/esphome-hassio-amd64:2022.2.6 "/init" 42 hours ago Exited (129) 36 hours ago addon_a0d7b954_esphome
8706xx7cc10c zigbee2mqtt/zigbee2mqtt-amd64:1.24.0-1 "/init" 42 hours ago Exited (129) 36 hours ago addon_45df7312_zigbee2mqtt
bba9dxx6fca7 ghcr.io/hassio-addons/node-red/amd64:11.0.4 "/init" 42 hours ago Exited (0) 36 hours ago addon_a0d7b954_nodered
85d6axx93535 homeassistant/amd64-addon-configurator:5.3.3 "/init" 42 hours ago Exited (0) 36 hours ago addon_core_configurator
ffd2exx4d5cd ghcr.io/home-assistant/amd64-hassio-supervisor "/init" 44 hours ago Exited (0) 36 hours ago hassio_supervisor
cdf5dfxx99dc ghcr.io/home-assistant/amd64-hassio-observer:2021.10.0 "/init" 3 weeks ago Up Less than a second 0.0.0.0:4357->80/tcp hassio_observer
But they don’t auto start. And trying to start them manually gives this
$sudo docker run -d --restart unless-stopped hassio_supervisor
Unable to find image 'hassio_supervisor:latest' locally
docker: Error response from daemon: pull access denied for hassio_supervisor, repository does not exist or may require 'docker login': denied: requested access to the resource is denied.
See 'docker run --help'.
How can this be fixed?
