I’m currently in the process of recreating my HAOS installation, and as it’s running on Proxmox, I’ve added a second (virtual) disk to the HAOS VM, and I would like to add and use it as the data disk. Except, although it is being detected as /dev/sdb, it cannot be used, because ‘no disks are available’.
What can I do?
The disk is listed in HAOS 8.4 as follows:
DEVLINKS: >-
/dev/disk/by-id/ata-QEMU_HARDDISK_QM00005
/dev/disk/by-path/pci-0000:00:07.0-ata-1
/dev/disk/by-path/pci-0000:00:07.0-ata-1.0
DEVNAME: /dev/sdb
DEVPATH: /devices/pci0000:00/0000:00:07.0/ata1/host1/target1:0:0/1:0:0:0/block/sdb
DEVTYPE: disk
DISKSEQ: '13'
ID_ATA: '1'
ID_ATA_FEATURE_SET_SMART: '1'
ID_ATA_FEATURE_SET_SMART_ENABLED: '1'
ID_ATA_ROTATION_RATE_RPM: '0'
ID_ATA_SATA: '1'
ID_ATA_WRITE_CACHE: '1'
ID_ATA_WRITE_CACHE_ENABLED: '1'
ID_BUS: ata
ID_MODEL: QEMU_HARDDISK
ID_MODEL_ENC: >-
QEMU\x20HARDDISK\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20
ID_PATH: pci-0000:00:07.0-ata-1.0
ID_PATH_ATA_COMPAT: pci-0000:00:07.0-ata-1
ID_PATH_TAG: pci-0000_00_07_0-ata-1_0
ID_REVISION: 2.5+
ID_SERIAL: QEMU_HARDDISK_QM00005
ID_SERIAL_SHORT: QM00005
ID_TYPE: disk
MAJOR: '8'
MINOR: '16'
SUBSYSTEM: block
TAGS: ':systemd:'
USEC_INITIALIZED: '4291858'
