HAOS VB installation error "Failed to fetch logs"
First time user installing in VirtualBox.
Everything appears to be OK but when accessing using the android app http:homeassistant.local:8123 after several minutes of green messages updating etc, the error message “Failed to fetch logs” appears with a Red Retry button. The Retry doesn’t help.
Any help with this would be appreciated.
how did you install?
Hi and thanx for your reply.
Since logging the problem, I reset the VB and successfully accessed HA
The only change I made was to select VMSVGA for the display.
Fingers crossed all continues to run ok
Thanx again.
