Haproxy and sunpower
I was able to get my Raspberry Pi in my Sunpower PSV6 box and install Haproxy on it.
I can communicate with the pi. I have power cycled the solar coms breaker, as well as the system, since confirming that the pi is in “PVS6 LAN1” following the https://starreveld.com/PVS6%20Access%20and%20API.pdf.
I still can not seem to be able to communicate with the PVS6 or able to pull it into Home Assistant.
What version of the Raspberry Pi OS are you running? I’m just in the middle of setting this up for my PVS6 but I’m running Bookworm on my Pi Zero W and step 3 in the Networking section says :
edit /etc/dhcpd.conf , add two lines to it, and save
however there is no such file on my system. there is a file:
/etc/dhcp/dhclient.conf
but its not clear whether the changes needed would be the same as in those instructions…
I tried using “nmcli” to prevent the default ipv4 gateway being set to the ethernet device, but i end up with no route to the PVS6:
$ sudo nmcli connection modify id ‘Wired connection 1’ ipv4.never-default yes
Tried explicitly adding a route to 172.27.153.1 with nmcli but still can’t get it to work. e.g. running
$ wget http://172.27.153.1/cgi-bin/dl_cgi?Command=DeviceList
yields a “no route to host” error.
Also, the ethernet interface on the Pi seems to lose its IP address after a while, not sure if this is because of the nmcli commands i’ve been messing with…
If anyone who is using a Pi running Bookworm to bridge the PVS6 to your network could help me with the network config, i’d appreciate it greatly :-).
got this working after doing:
$ sudo nmcli c modify “Wired connection 1” ipv6.never-default true
$ sudo nmcli con up “Wired connection 1”
and restarting.
