Hardwired PoE Smart Air Exchanger: Venmar Constructo + Waveshare 8-ch PoE Relay & Home Assistant
Tired of wireless smart plugs and Zigbee relays dropping offline in basement mechanical rooms? Want to stop freezing Arctic air (-25°C) from entering during Hydro-Québec or dynamic peak pricing events without breaking factory wall switches?
Here is a complete engineering and automation guide for converting a Venmar Constructo 2.5 (Model 45110) or equivalent Broan/Nutone HRV into a local 2-speed smart ventilation fan with hardware button lockout using a Waveshare 8-ch PoE Ethernet Relay Module (SKU 24964).
Full GitHub Guide & Schematics:
Key Highlights & Real-World Findings
- 100% Local PoE & Modbus RTU over TCP: Single Cat6 drop for 802.3af PoE power and Modbus RTU communication over TCP (port 4196). No Wi-Fi, no Zigbee mesh dropouts through concrete foundations.
- The Symmetrical 4-Relay Defragged Architecture:
- Zone 1 (Bathroom OC): Relay 1 (NC) in-series for bathroom button lockout; Relay 2 (NO) across OC & OL for HA High Speed Boost.
- Zone 2 (Upstairs B): Relay 3 (NC) in-series with ground for wall control lockout; Relay 4 (NO) across B & G for HA Low Speed.
- Fail-Safe NC (Normally Closed) Lockouts: Relays 1 and 3 are de-energized 99% of the year. Factory bathroom buttons and wall controls function 100% autonomously if Home Assistant or the relay reboots.
- Winter Peak Lockdown: Energizing Relays 1 and 3 during peak events physically prevents anyone from accidentally pressing a bathroom boost button and sucking freezing outdoor air inside during 53¢/kWh peaks.
- Modern Template Fan Integration: Full YAML for modern
template: - fan:schema (no deprecatedfan: - platform: templatewarnings) with mutual interlocks. - Automations Included: Smart Dehumidistat via Nest humidity sensors, 20-min High Speed boost auto-off, and 3-stage Hydro-Québec dynamic peak management.
