Anyone have any working configurations files with the Harmony Hub that they can share with me?
Not sure if I need to install any 3rd party files or if it should just work? I’ve got the Harmony Hub listed in my GUI, but not any of the activities— so pretty much I’m kind of lost in terms of setting up the harmony configuration to the way my Harmony Hub currently reads them out. Any tips or pointers would be appreciated!
You should have a harmony_NAMEOFYOURHUB.conf file in the root of your HA install, same one your other config files are at. That will list all your activities and remote commands. Start there and read the docs here:
They do a pretty good job of laying everything out and you can use the examples, replacing the command strings in the example with the ones you found in the step above.
