I’ve just installed HA and started to configure it. I’ve a noob question… can I use my Harmony Ultimate Remote to trigger HA automations? I mean, defining the automation in HA and showing it in the remote.
(my goal is having a activity at the remote to start hyperion service at rpi and switch on/off a tp-link smart plug)
I have a harmony hub and what i was able to do was turn on the emulated hue component and then create scenes and scripts that are then treated as hue bulbs. you can then assign them to activities or buttons on the remote.
What I need is a new activity… because my hardware is not compatible (tp-link hs100 & stop a rpi service) with Logitech Harmony and I cannot create an activity from Logitech software
So… need some way to make new IR commands that can control home assistant with some IR receiver attached to the HASS server, teach harmony these commands, then you can change what buttons do and control home assistant with buttons of your choice.
I didn’t want everything showing up, so I turned off Expose by default
expose_by_default: false```
Then in my customize file, I turned on each individual scene/script that I wanted to be recognized
``` scene.good_night:
emulated_hue: true
emulated_hue_name: "Good Night"```
After that was complete, I went into the harmony app to Menu> Harmony Setup> Add/Edit Devices & Activities> Devices> Add Device> Home Control> Phillips Hue
After that is complete you can create a new activity where each "bulb" is listed as a device
<img src="//community-assets.home-assistant.io/original/2X/b/b75fd50a3c89f3bde6d3d65f99ab4407869bfa89.png" width="281" height="500">
Hopefully that is enough to help you get started.
Are your hue bulbs in HA? You can unlink the “real” hue bridge and still access the hue bulbs when you add the emulated hue component. Not sure if that will work for you, but could be an option.
