HarmonyHubControl Webservice Response Error/ Autostart Problem?
Does anyone use HarmonyHubControl? If so, I just started experience an issue when using a command line switch. I get a LOGITECH WEB SERVICE LOGIN: FAILURE, and get the error “Logitech web service response does not contain a login authorization token”. I haven’t had any issue with this in the past, and didn’t make any change to the configuration. If I run the command straight from the command prompt, it works no problem. Any ideas?
EDIT: Was able to fix this, as my Autostart in systemd seemed to be interfering with the commands. Any idea how I can fix this?
