I am running HASS 0.38.2 all in one installer on a Rpi 3 which has been running for about 6 months fine, but the last couple of days the pi has crashed twice. both times I couldn’t even ssh…I have had to hard reset to get it back.
I’m not very familiar with linux and am not sure how to diagnose.
Whats the best approach with this? I’m not really keen to rebuild the pi.
There is nothing obviously wrong I can see at the moment.
I understand there is a memory leak in version 0.39, and it could be that it was also present in version 0.38.2, so I would keep an eye on the RAM Free. If that goes down consistently, try restarting HA to see if it increases again. If you run out of RAM it would have the symptoms you describe.
Looks like I have fixed this (Big thanks to Graham). The problem was with the SD card- semi corrupt.
I restored the image on a new sd card and it appears stable again.
Learning about SD cards now
