Hey Guys,
I`m fresh here from the OpenHAB because i dont like the system and search for a better.
HASS should be fine for me. By the way sorry for my bad englisch I´m from Germany …
I have added hass-configurator.systemd and settings.conf from this GitHub on my Raspberry Pi 3b with Raspbian Stretch and manually installed and runned home-assistant.
When i start:
$ sudo systemctl status hassconfigurator
i get following:
hassconfigurator.service - HASS-Configurator
Loaded: loaded (/etc/systemd/system/hassconfigurator.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2018-02-05 20:31:13 CET; 2min 38s ago
Process: 616 ExecStart=/usr/bin/python3 /home/homeassistant/.homeassistant/configurator.py settings.conf (code=exited, status=210/CHROOT)
Main PID: 616 (code=exited, status=210/CHROOT)
Feb 05 20:31:13 raspberrypi systemd[1]: hassconfigurator.service: Failed with result 'exit-code'.
Feb 05 20:31:13 raspberrypi systemd[1]: hassconfigurator.service: Service hold-off time over, scheduling restart.
Feb 05 20:31:13 raspberrypi systemd[1]: Stopped HASS-Configurator.
Feb 05 20:31:13 raspberrypi systemd[1]: hassconfigurator.service: Start request repeated too quickly.
Feb 05 20:31:13 raspberrypi systemd[1]: Failed to start HASS-Configurator.
Feb 05 20:31:13 raspberrypi systemd[1]: hassconfigurator.service: Unit entered failed state.
Hope anyone can help me.
I´m very new on Raspi, linux and smarthome automation.
Thanks a lot.
Best Greetings
Ned
