HASS doesn't start after configuring DLIB
After configuring Dlib including this lines in configuration.yaml (following https://www.home-assistant.io/integrations/dlib_face_detect/)
Example configuration.yaml entry
image_processing:
  • platform: dlib_face_detect
    source:
    • entity_id: camera.door
What happens is that HASS doesn’t start showing this in log:
2020-06-21 16:25:54 DEBUG (Recorder) [homeassistant.components.recorder] Connected to recorder database
2020-06-21 16:26:13 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=27026 from 2020-06-21 16:25:54.676522)
Over and over again.
If I comment image_processing configuration y configuration.yaml HASS starts up normally.
I’m running HASS in a docker container here you will see version:
/config # hass --version
0.111.4
and docker is running in UBUNTU 18.04 if I run unman -a you will see this
4.15.0-106-generic #107-Ubuntu SMP
Thanks in advance
Isnel.
