With version 0.65.5 of hass.io I get some strage error:
I want to report this error maybe some experts correct it.
Best regards,
noro
Best regards,
noro
same issue here
2018-03-23 21:01:56 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal error on SSL transport
File "/usr/local/lib/python3.6/asyncio/sslproto.py", line 636, in _process_write_backlog
ssldata, offset = self._sslpipe.feed_appdata(data, offset)
AttributeError: 'NoneType' object has no attribute 'feed_appdata'
Version 0.65.6
this seems te be related
What python version are you using? i am running 3.6.4
At that time was the last version. I wanted nobody criticise, just help…
Best regards,
Noro
Did you find a solution to this problem? I’m getting very similar issues
I have the same problem today. I have HA 0.82.1 on Synology DSM 6.2
