Hass.io Add-ons: RPi MySensors Gateway
About
A RaspberryPi has a spi interface. So why don’t connect directly an rf24 device?
This add-on permits to use the RasperryPi GPIO to connect an nRF24L01P device and use it as an internal MySensors.org Gateway.
Info on MySensors pages
Note
!ONLY! nRF24L01P is supported!
Installation
The installation of this add-on is pretty straightforward and not different in
comparison to installing any other Hass.io add-on.
Add our Hass.io add-ons repository to your Hass.io instance.
Install the “RPi MySensor Gateway” add-on.
Start the “RPi MySensor Gateway” add-on
Check the logs of the “RPi MySensor Gateway” add-on to see if everything went well.
Configuration
Note: Remember to restart the add-on when the configuration is changed.
Example add-on configuration:
"rebuild": false,
"log_level": "debug",
"channel":75,
"pa_level":"RF24_PA_MAX",
"ce_pin":22,
"cs_pin":24,
"use_irq":{
"rx_buffer":20,
"pin":15
"use_led":{
"err_pin": 12,
"rx_pin": 16,
"tx_pin": 18
Note: This is just an example, don’t copy and paste it! Create your own!
Info: For detailed specifications go on MySensors pages
Option: rebuild
Force the MySensor build to clean all ONLY FOR TEST
Set it true
to enable it, false
otherwise.
Option: log_level
The log_level
option controls the level of log output by the addon and can
be changed to be more or less verbose, which might be useful when you are
dealing with an unknown issue. Possible values are:
debug,info,notice,warn,err
debug
: Shows detailed debug information. -
info
: Normal (usually) interesting events. -
notice
: Normal (low verbose) interesting events. -
warn
: Exceptional occurrences that are not errors. -
err
: Runtime errors that do not require immediate action.
Please note that each level automatically includes log messages from a
more severe level, e.g., debug
also shows info
messages. By default,
the log_level
is set to info
, which is the recommended setting unless
you are troubleshooting.
Option: channel
<0-125> RF channel for the sensor net. [76]
Option: pa_level
[RF24_PA_MAX|RF24_PA_LOW] RF24 PA level. [RF24_PA_MAX]
Option: ce_pin
Pin number to use for rf24 Chip-Enable.
Option: cs_pin
Pin number to use for rf24 Chip-Select.
Option: use_irq
Only applies if external irg pin is connected.
Option: use_irq.rx_buffer
Buffer size for incoming messages when using rf24 interrupts. [20]
Option: use_irq.pin
Pin number connected to nRF24L01P IRQ pin.
Option: use_led
Only applies if led are conneted.
Option: use_led.err_pin
Error LED pin.
Option: use_led.rx_pin
Receive LED pin.
Option: use_led.tx_pin
Transmit LED pin.
Known issues and limitations
MQTT is not supported.
Serial communication is not supported.
RFM69 is not supported.
RS485 is not supported.
Security is not supported.
Support
Got questions?
You could also open an issue here GitHub.
Authors & contributors
The original setup of this repository is by Lucio Tarantino.
