I noticed this morning that the ha-dockermon sensor has been depreciated in favour of docker_monitor however unlike dockermon which relies on a docker container of its own, docker_monitor requires docker.sock to be exposed to the homeassistant container.
If I was using the homeassistant docker container without Hass.io, i’d mount the file using the “-v /var/run/docker.sock:/var/run/docker.sock” flag and away we go - however from what i can see the supervisor controls the homeassistant container, so is this possible using Hass.io?
It is monitor so read only mount is likely best and will be OK.
-v /var/run/docker.sock:/var/run/docker.sock:ro
EDIT
Look like NO, docker-monitor need mount when build container.
BUT why not continue use ha-dockermon? It should continue to function since it is using HA Rest Integration for connection with HA
Based on my reading of how the sensor works, yeah it effectively means that the docker container is redundant.
It also does not appear to have the ability to monitor ‘remote’ docker instances either like hadockermon can - I’m currently monitoring an instance on a RPi and my Synology box as well as the one on my HA Server
