Dear friends,
trying to install hass.io as a docker image on a running RPi4 with all prerequisites installed.
Launched the install file as follows:
root@bob> bash hassio_install.sh --machine raspberrypi4
waited some 15 minutes and tried connecting my browser to IP:8123 but no go.
On the host RPi4 I see the following:
hi there trying to install a container hosted hass.io on a raspberry Pi4. Used the hassio-installer.sh on github with --machine raspberrypi4 as its parameter. IP:8123 does not respond and I see the following on the raspberry. Is it normal? What can I do?
root@rpibuster:/home/bob# docker container ls
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
e7dfa935b519 homeassistant/armv7-hassio-dns:1 "coredns -conf /conf…" 33 minutes ago Up 33 minutes hassio_dns
3a3125f771df homeassistant/armv7-hassio-supervisor "/bin/entry.sh pytho…" 33 minutes ago Up 33 minutes hassio_supervisor
and also
root@rpibuster:/home/bob# docker network ls
NETWORK ID NAME DRIVER SCOPE
14d91bbb8ab5 bridge bridge local
58344c00a814 hassio bridge local
447a8e211ea1 host host local
e17eb3b0dc7c none null local
does this look normal? Any idea on how to return to a pristine docker situation and perhaps start from scratch?
Thank you
