So I tried to install hass.io using the script on a ubuntu 16.04 host. (i.e. curl -sL https://raw.githubusercontent.com/home-assistant/hassio-build/master/install/hassio_install | bash -
Docker hello world is running without a problem.
But it seems that i cannot connect to any SSL page:
$ sudo docker logs hassio_supervisor
starting version 3.2.4
18-02-13 22:15:10 INFO (MainThread) [__main__] Initialize Hassio setup
18-02-13 22:15:10 INFO (MainThread) [__main__] Setup HassIO
18-02-13 22:15:10 WARNING (MainThread) [hassio.utils.dt] Can't fetch freegeoip data: Cannot connect to host freegeoip.io:443 ssl:True [Connection refused]
18-02-13 22:15:10 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to supervisor homeassistant/amd64-hassio-supervisor with version 0.88
18-02-13 22:15:11 INFO (SyncWorker_1) [hassio.docker.interface] Attach to image homeassistant/qemux86-64-homeassistant with version landingpage
18-02-13 22:15:11 INFO (MainThread) [hassio.addons.git] Clone addon https://github.com/home-assistant/hassio-addons repository
18-02-13 22:15:11 INFO (MainThread) [hassio.addons.git] Clone addon https://github.com/hassio-addons/repository repository
18-02-13 22:15:11 ERROR (MainThread) [hassio.addons.git] Can't clone https://github.com/home-assistant/hassio-addons repo: Cmd('git') failed due to: exit code(128)
cmdline: git clone --recursive -v https://github.com/home-assistant/hassio-addons /data/addons/core
stderr: 'Cloning into '/data/addons/core'...
fatal: unable to access 'https://github.com/home-assistant/hassio-addons/': Failed to connect to github.com port 443: Connection refused
18-02-13 22:15:11 ERROR (MainThread) [hassio.addons] Can't load from repository core
18-02-13 22:15:11 ERROR (MainThread) [hassio.addons.git] Can't clone https://github.com/hassio-addons/repository repo: Cmd('git') failed due to: exit code(128)
cmdline: git clone --recursive -v https://github.com/hassio-addons/repository /data/addons/git/a0d7b954
stderr: 'Cloning into '/data/addons/git/a0d7b954'...
fatal: unable to access 'https://github.com/hassio-addons/repository/': Failed to connect to github.com port 443: Connection refused
18-02-13 22:15:11 ERROR (MainThread) [hassio.addons] Can't load from repository https://github.com/hassio-addons/repository
18-02-13 22:15:11 INFO (MainThread) [hassio.addons] Load addons: 0 all - 0 new - 0 remove
18-02-13 22:15:11 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
18-02-13 22:15:11 WARNING (MainThread) [hassio.updater] Can't fetch versions from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json: Cannot connect to host raw.githubusercontent.com:443 ssl:True [Connection refused]
18-02-13 22:15:11 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
18-02-13 22:15:11 INFO (MainThread) [hassio.addons] Startup initialize run 0 addons
18-02-13 22:15:11 INFO (MainThread) [__main__] Run HassIO
18-02-13 22:15:11 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
18-02-13 22:15:11 INFO (MainThread) [hassio.supervisor] Update supervisor to version None
18-02-13 22:15:11 INFO (SyncWorker_1) [hassio.docker.interface] Pull image homeassistant/amd64-hassio-supervisor tag None.
18-02-13 22:15:12 ERROR (SyncWorker_1) [hassio.docker.interface] Can't install homeassistant/amd64-hassio-supervisor:None -> 404 Client Error: Not Found ("manifest for homeassistant/amd64-hassio-supervisor:None not found").
18-02-13 22:15:12 ERROR (MainThread) [hassio.supervisor] Update of hass.io fails!
I further checked and indeed the supervisor cannot connect to any SSL page.
$ sudo docker exec -i -t hassio_supervisor /bin/bash
bash-4.4# apk --no-cache add curl
fetch http://dl-cdn.alpinelinux.org/alpine/v3.7/main/x86_64/APKINDEX.tar.gz
fetch http://dl-cdn.alpinelinux.org/alpine/v3.7/community/x86_64/APKINDEX.tar.gz
OK: 125 MiB in 40 packages
bash-4.4# curl https://google.com
curl: (35) error:1400410B:SSL routines:CONNECT_CR_SRVR_HELLO:wrong version number
$ bash-4.4# nslookup github.com
nslookup: can't resolve '(null)': Name does not resolve
Address 1: 192.30.253.112 lb-192-30-253-112-iad.github.com
Address 2: 192.30.253.113 lb-192-30-253-113-iad.github.com
bash-4.4#
Has someone an idea?
