Hass.io issues with restart
Hi guys after the restart failed from Hass.io i’ve to try from Putty and it works.To find the issue i’ve controled the log with Putty and find this problem.
s6-svwait: fatal: timed out
[s6-finish] sending all processes the TERM signal.
2020-03-31 19:20:18 INFO (MainThread) [homeassistant.core] async_stop called twice: ignored
s6-svscanctl: fatal: unable to control var/run/s6services: supervisor not listening
[s6-finish] sending all processes the KILL signal and exiting.
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] udev.sh: executing…
[19:20:23] INFO: Update udev information
[cont-init.d] udev.sh: exited 1.
[cont-finish.d] executing container finish scripts…
[cont-finish.d] done.
[s6-finish] waiting for services.
Anyone can help me? Because i don’t know what to do to solve this problem.
Did you ever figure this out? I just ran into this myself.
I would start by backing up the config files and install a new SD card with HA, boot, put my config back, reboot.
So basically, something got corrupted, and at this point it’s just best to start over with a backup/restore?
Well, it’s not clear. But since it’s made to be pretty easy to restore from a backup / snapshot I would try that. It’s far easier then figuring out what exactly went wrong.
From the version 107 i’ve this problem with hass.io on a rasp pi3b+ with ssd.Before the 107 version no problem.
I prefer to don’t restore again and find the problems.
Sometimes It happen,sometimes not.
From SSH with putty i can restart but i prefer find the problem without restoring
