Just upgraded from 0.76.2 to 0.77.2. Hassio menu item is now missing from left side menu. Not blank like in 0.75.0 but gone. How do I get it back? Running on Pi3, still on ResinOS.
Check you configuration.yaml, you probably removed or commented out discovery:
If you did comment out " discovery: " adding " hassio: " to your config will bring it back.
I know this because I’ve been there. =)
Thanks. It turned out that while trying to fix my CustomUI issue I had commented out frontend:
All good now!
