Hass.io On Hyper-V - Step By Step
Worked for me too ! Thanks a ton
I noticed the latest VHDX image (v5.8) is now a 32GB image file. Supposedly it’s still a dynamically expanding image so why does it take up the full space? This was not the case with v4.20, this was a 6GB image.
Why was this changed? A clean install now takes up 26GB more than it did previously.
I figured out a way to shrink the image back to about 4,5GB again:
  • Using Hyper-V Manager start the New Virtual Hard Disk Wizard
  • Format: VHDX
  • Type: Dynamically expanding
  • Give it a name
  • Configure Disk: select “Copy the contents of the specified virtual hard disk” and select the 32GB VHDX file from the OP.
  • Press finish and a new 4,5GB VHDX file is created, use that file in stap 8 of the OP for your VM.
This saves you 25GB of space on your Windows host.
How do I install alpine packages in this image without them dissappearing the next time I login. I have run apk add to install a few things, like nano, but they are gone when I login next.
So the link for the VHDX file is now gone, where do I download this?
Ctrl+F for vhdx
Hello everyone
I feel pretty stupid. I did all those exact steps and im still only getting the Home Assistant installation, without the hass.io plugins. I aswell tried to edit the configuratoin.yaml and adding hassio: and discovery: to it. But I still don’t see the addons: i went with the official installation and download link and double checked it with this one aswell. Any ideas?
https://www.home-assistant.io/installation
hassos_ova_512 is the file.
what is the default username and password to log into the VM using RDP?
Is there any way to passthrough bluetooth dongle to Hyper-V? I mean, i sucessfully added Zigbee adapter as serial-to-ethernet, but bluetooth is different. I’m trying to setup " Passive BLE monitor integration". I know about ESP32, but now i’m unable to get one.
Not sure if it helps, but before I used serial2net (eltima) to pass zigbee data from usb to HyperV over network, I worked around it by running MQTT server on windows….and let HA (on HyperV) connect to that one, instead of using HA’s internal MQTT add-on :wink:
Can confirm. Serial to Ethernet Connector is working beautifully. For Zigbee and Z-Wave that’s perfect solution. Be sure to set COM port as in below screenshot if you have CC2531 stick.
Screenshot_1
Don’t know how to pass Bluetooth to Hyper-V, though. Server part is okay, but how to install client into HASS Hyper-V?
Thanks that worked great.
I have a “small” Problem with my ha installation in hyperv.
It’s getting very large, it’s already up to 50GBs and I don’t know what it could be.
So first what it is not:
  • Home Assistant Database
  • Unused Docker Images
  • Videos or any media saved that I know of
And it’s not getting smaller everytime I restart the vm it’s getting a little bit bigger.
Any ideas?
So no one got an Idea for this?
Could it be that your Hyper-V is creating Checkpoints? See this: Enable or disable checkpoints in Hyper-V | Microsoft Docs
Sadly not.
Just did everything from “scratch”.
Did a backup of my HA Installation and recreated the VM.
Now it’s only 8GB.
I also disabled Checkpoints now.
default switch isn’t even an option in mine, i get Intel X550 virtual switch. i can’t remember if i i changed something.
my VMs are getting 172 addresses.
EDIT: what are people needing USB for? Z wave? smart hubs? they ain’t making those with ethernet so that you don’t need USB? needing to plug in to a pc USB seems kind of archaic for things that would go in walls and ceilings (for best wireless coverage) but i digress.
ok so dhcp reservation then
but a static ip can be set via ui now…
With the latest file I cannot rename the vhdx… anyone else have this problem? I am a little OCD when it comes to file naming and homelab organization.
if I rename it fails to mount and goes into emergency mode. If I leave it then it is fine. I even rename it before creating the VM so I know its not a link error in hyperV
Figured this out, let it boot at least once before renaming!
